Thanks Ian I'll take a look at your thread, what is not clear to me is if all Weber 30 DGF are the same ( besides jets) or it have to be from fiat panda. Anyway more on carbs later because I am still running for the head repair and each work like welding, thread repair, valves seats etc has to be in a different shop no-one is doing all the work. So I'm on the run.Hi Thomas, if you look at my old thread @
Weber 30 DGF 1/252 service
you will find all the information you need about the correct jets for the carb. Just in case the carb you find does not have the original jetting.
For information It was recommended by my engine man that I use a new set of jets - All one size above standard to help with the running in process - the richer jets help keep the piston crown cooler and when run in change back to the leaner original jets. Hope this helps.
Ian.
