Technical Location parking sensor module?
Marcel de Hoog
Does anyone know in where in a Ducato (2012) the canbus module of the parking sensors are located?
My parkings sensors are no longer fitted, and I keep getting an error about it as the cars computer thinks they should be there. Easy to wipe the error with MES, but I cannot entirely disable them there. Clueless where I can find the module to disconnect.
Hi Marcel
Here is a picture for the Peugeot Boxer. The module is the part labelled No 1. I would expect the Ducato to be the same. It is probably inside the corner pillar, near the light cluster.
Thanks Anthony. I have looked in both pillars but not found it, I will do another check soon as I really want it gone!
Okay the issue was that I covered the place where the module is located when I did my walls. After cutting a hole (behind the plastic covers, so not visible afterwards) it was easily found.
Removing the connectors and proxy alignment, no more errors, yay!
