Lights
Lights
aegirling
Cornwall
My console doesn't light up when I switch on my lights can any one help
Welcome. Try a search in the Mk3 forum. I wouls suspect mass bulb failure. Try removing one switch and testing to see if a. you have blown bulb, and B if there is voltage when side lights are turnedcon.
Thanks for the reply how do I do that can you tell me in detail
Look on the left and hit the forums tab
Scroll down untill you get to Pandas and then click on the Mk 3
That gets you to the right forum.
Go to teh search tab on the right of the screen and click on that and you will see some options. Just type in key word such as heather controls or heater lights. A bit of trial and error brings up previous threads in a list and you can then open up something that looks likely. This usually seems to leadme on to somehting useful,
Using different search words gets different results as its a computer and does computery responses that are not always exactly what you want.
Click the drop down box that appears "everywhere and change it to this forum to stay looking at Panda Mk3s.
Also have a look in guides as there has been a few good things published about changing the bulbs.
I hope this helps a little.
