I'm after a new pair of fog light type headlights for my 2005 pre facelift Doblo. All the on-line suppliers seem to be outside the UK. Can anyone tell me if the LHD and RHD headlight units are the same ?
Hey Wesley, yes, there is a difference between the LHD and RHD headlamps as to how the light is projected.
The only place i can suggest that i used and always provided new original parts is shop4parts.co.uk.
Hope you find what you need
Yes, some fiats do have this, unfortunately I’ve found that it’s ‘hit n miss’ as to which are fitted and which not, EVEN on the same car/van..on both my brothers alfa mito’s they had a spring loaded reflector, accessed through the rear, which was moved by a simple sprung wire with a plastic end
Car has JUST passed MOT 1/2 hour ago I was expecting a fail on the headlights hence the original posting but looks like I can put off the expense a little longer
