beeson100
Has anyone tried the Koni STR.T or is everyone on the sports? I only ask because the STR.T is about half the price!
John
John
John
If the settings are right for the model you have it would be the answer, of course, but the fact that it's non-adjustable and is the unit they sell for the whole (2wd) Panda range means that it's not going to be optimal for more than one Panda variant.
.... I think its worth a try!
Fiat Panda 100HP alignment settings
Front caster
Left was 2.3° now 2.1°
Right was 2.3° now 2.3°
Camber - didn't use the camber bolts!
Left was -1.4° now -1.1°
Right was 1.1° now 1.1°
Front toe
Left was 0°12’ now 0°03’
Right was 0°45’ now 0°03’
Any particular reason you guys are just buying the rears? Obviously the main issue with the Panda/500 platform is the rear suspension, but if you're going to improve the rear and leave the front standard then that's not exactly ideal.
From my point of view it's to see what a difference the rears make with a view to changing the fronts later if I like the results - which are positive so far - it'll have to wait till July when we come back from Italy. Maybe changing both ends at once introduces too many unknowns to the equation. As you say, the main issue is with the rear end, and it also spreads the cost. My 100HP was having a (nearly) 36,000-mile service anyway last week, prior to the Italian trip - this included swapping the wheels front-to-back so putting the rear dampers on only added a couple of minutes to the labour costs. Incidentally, the disk pads were checked and they're still the originals.
I suppose so
I guess I just take the view that I'd rather drive around on standard suspension for a bit longer and then get a full set of dampers done.
Well I think as well engineered as those cars are bilsteins or konis will always improve any car.
Because manufacturers simply don't want to spend the money on decent dampers when a lot probably won't know? That said some manufacturers like Subaru have Spec-B models. The B stands for Bilstein, and quite a few people go for them because they know the suspension is going to be decent.Well, I suppose that's my point really - how come Koni or Bilstein can come up with a better solution even on cars that are relatively price-insensitive?
