Fuses are all untouched, but they are also not the standard 8a, but 16a and one is 25a...
So, I went through the electrical diagram, and cleaned out each connector, tried inverting cables, etc but the only thing I managed to solve is the high beam light (blue). It now turns on when high beams are on.
The indicator light on the left of the dash still doesn't work, and it's not a housing issue, because I inverted the high beam and indicator lights to see, and it's definitely a signal issue.
I used a multimeter to go through each cable/switch/lightbulb, and they all gave back a signal (using the ohm open circuit setting).
I'm trying to figure out which earth points to go through, and considering that the light switch + headlights/position lights/indicators work, I don't get how, for example the rear license plate light, doesn't work, when it's in the same circuit as the tail lights (and those work)
Here is the mess that is the fuse box, don't worry, rubber grommets are on the way:
Main lights switch:
Wiper switch and key:
Dashboard lights switch + high beam blue light:
After cleaning the switches, and light bulb connectors etc, the only thing I've succeeded in was to get the high beam (blue) light to work. I'm also facing the issue of the green light on the dash being inverted (so being on when the lights are off, and it goes off when I turn on the lights :bang
. I've inverted the switch leads but it doesn't change....
