Technical How to detach Gear cables linkages?
Navin Talati
This is about the Fiat Palio 1.2 nv petrol.
I need help for removing the Gear shifter Rod and Support Block (white plastic) of the car.
It is linked with Selector and Engagement cables for gears. The cables are attached through linkages as shown in the picture.
Colud anyone help me by guiding, - How to detach these linkages?
Urgently required.
Thanks to all in anticipation.
Navin Talati / 27-02-2017
Navin I think u may already have the fiat brava workshop manual, if not I will try and post the link, I myself have to check How this can be removed from what it looks like those linkage are sealed or pressed into. Let me try some digging and get back
I carefully tried to release the linkage and could do it. So far as the Fiat Palio 1.2 nv car is concerned, this linkage is simply Pull-Press type. No need to remove mounting and fixing clips of the Engagement and Selector cables. Somply release the Gear Lever Housing (white plastic block) from inside the car cabin by undoing the 4 nut-bolts (10 mm) and make the gear stick free to
move and twist. Then you can release these linkages easily.
See the picture.
Thanks to all.
Navin Talati /28-02-2017
