Oliverkd123
- Joined
- Jul 19, 2020
- Messages
- 1
- Points
- 1
good evening all.
just doing the run up to the mot for the old girl (1991 fiat ducato camper diesel - compass calypso)
having issues with the indicators. the previous owner has converted the tail light clusters to led and switched out the flasher relay to an adjustable one for the leds. the issue im having is that now none of the indicators are working and i have had them working in this config previously even off the hazard switch nothing. i get the flashing light on the dash and i can hear the relay clicking away normally but no lights on the outside. could any of you fine folk help. i have tried the fuses and 2 new relays and also direct power to the new led indicator light on the rear cluster and i do get the front to light up but nothing from within the van itself.
also is it normal for the tail lights and dash back light to only work off the park light switch or should it also work from the stalk (side dip and full)
again thanks in advance.
Oliver
Oliver
