- Joined
- Nov 18, 2015
- Messages
- 63
- Points
- 21
What's best way to replace my dipped beam and fog front passenger stilo 05 plate keeps popping had it replaced 2 month ago
It IS possible to do it with the battery still in place by going from above and below the car although you risk damaging the bulbs this way. I'd just suggest removing the battery and then just removing the battery holder, which is held in place by two bolts and a phillips screw. Depends how much time you have but removing the battery and holder gives you a LOT more room.
You could also remove the wheel arch on the nearside well but I'd say that was harder and more time consuming than removing the battery. If you choose to do that then there's only six philips screws to remove.
Next time i think i will remove the washer bottle and possibly the battery and tray for passenger side...
Quicker to remove the bumper than the washer resevoir and battery tray.
