Technical hard to get into 5th
That's what happens when thread posts change topic all over the place...I was talking about lubricating the clutch lever (fork) upper bush/shaft...not what oil goes in the engine or gearbox!
I bought a LUK clutch and it is so poorly designed, the thrust bearing would eat through the pressure plate very quickly, so I fitted an AP. AP appears to be the standard now and is what I would recommend along with Valeo.
LUK.
AP.
LUK.
AP.
Hi thanks for replys uv sorted the creak without taking anything off just used 1l engine oil to lube it up let it soak everyday it may have had a AP clutch fitted as it's done 82k wen I got it so clutch has bound to been replaced I'm just going to do a gearbox oil change I think should make it run smoother!
