stolenbike
Can I use a Grande Punto jack kit on a Fiat Bravo?
a threaded bar approx. 75mm long, painted red, which is screwed into one of the wheel bolt holes in the hub to assist in refitting a roadwheel (helps locate the wheel on the hub while the other wheel bolts are being inserted), which is fitted in the vacant slot to the right of the jack handle.
Certainly, here you go :-Can you add a photo of this?
I have made my own.. but never seen a 'Factory' one
I suspect the jack kit would work well enough (having not used a supplied jack in 20+ years..)
I've posted a pic of the red painted threaded bar in the above post. Here are pics of the screwdriver and plastic wheel bolt insertion tool, in case anyone is interested. The screwdriver blade is reversible and is No. 2 point Philips at one end and a slot at the other end. The plastic wheel bolt insertion tool is sized 17mm at one end (to fit the wheel bolts) and 10mm on the other end (not sure what this is intended to be used for, maybe air filter removal? idk, maybe someone here has figured it out?). There are numbers on the larger end, 3 with B340 underneath (maybe this type of tool comes in other sizes? idk).What you show in the above pic. looks identical to what was supplied in my '08 Bravo 2, so I'd say yes, it can be used.
There would appear to be 2 items missing - a black plastic-handled screwdriver with reversible blade (No.2 pt Phillips and slot tips) which is fitted in the vacant space adjacent to the wheelbrace/spanner and a threaded bar approx. 75mm long, painted red, which is screwed into one of the wheel bolt holes in the hub to assist in refitting a roadwheel (helps locate the wheel on the hub while the other wheel bolts are being inserted), which is fitted in the vacant slot to the right of the jack handle.
In case you weren't aware of this, in the bottom of the tool tray there is a plastic tool that can be used to hold/fit/initially screw in the wheel bolts before using the wheelbrace (the bolts heads fit in recesses in the wheel so there's not much room to screw them in with your fingers).
A couple of further thoughts:-
