Fuel Filter
Fuel Filter
Erbl
Hi. Got filter from shop. Gave me this one. Is the one on car sealed? Or does it come off at top? Photos included.
Does not look the same to me, the one in the photograph looks like a sealed canister one, the one you have been supplied is a renewable element type. With filters there could be two or sometimes three possible fuel manufacturers. Double check they have given you the correct one.hope that helps, are you doing a service or trying to fix a problem?
Taking good few seconds to start. & have to rev few secs. As sounds like its gonna cut out. After its run it starts ok
That's were i got filter. Europarts. Can't get onto their webpage must be down
£120..??
NOT dissimilar to my Grande MJ filters.. they were @£30
Those filters with 'snap.seal' connectors dont have an air bleed
They have a constant tank return line.. ;)
A few cycles of the tank pump to purge air before Cranking the Engine should minimise airpockets in the High Pressure fuel delivery system
How long did you allow to purge?
Did you use any detergents at Service time..??
Replaced it for this one. Which looks like mine. With discount was £65.99.? bit pricey for a filter
