General Fuel cut off switch
hawkster
cheshire
Hi can any one help out got error fuel cut off switch was fine till park up come bk to cat and nothing .. on screen fuel cutting off show on dash
Looked for this in many places . But to no joy even indicator reset no joy as well I am getting frustrated with this can any on help in how to solve
Hi can any one help out got error fuel cut off switch was fine till park up come bk to car and nothing .. on screen fuel cutting off show on dash
Fiat punto evo 2011
How old are you?
Learn how to use internet properly before you start another thread like that (there is plenty of them out there).
Where is it? How it works? I don't have one installed (then what), and so on...
https://www.google.com/search?q=Fuel+cut+off+switch+fiat+evo
Also, there is procedure involving indicators (you blink left - right couple of times, Google that too, maybe you've performed the procedure wrong way).
Fuel system is simple. Battery, relay, pump, inertia switch (it sends signal to the Body Computer), that's all.
Example only (it's Grande, not EVO, there might be a differences). Cut-off switch is called I050.
https://4cardata.info/elearn/199/2/199000000/199000001/199000000/199001415
https://4cardata.info/elearn/199/2/199000000/199000001/199000000/199001297
Check bad connections first (we have sticky thread for that one too).
Pro-tip: EVO owners. Search for Grande first (problems, solutions, Guides, instructionals). There is more info about it (than EVO or "2012").
Hi 🙂
As a 1st attempt.. I would remove the battery negative cable for an hour..
Breaking the circuit.. And letting things power down may well reset something on the restart
Next Is a pair of jumpleads..
But we will see how you get on 🤔
Last thread I recall seeing on here involved a slightly awkward technique to reset using controls..
I will try to send link to that 🙂
