I have a 1993 Fiat UNO 70 ieSX, 1372cc with the Bosch Mono-Jetronic Fuel Injection System.
Driving to work last week after just filling the tank with fuel the car splutterred then ground to a halt, it felt like the car had ran put out of fuel.
Called the AA & after a few checks we found that no fuel was being pumped from out of the fuel tank, so I got towed home then began checking everything.
I removed the fuel pump & fuel filters, the fuel pump was then checked on an external car battery and worked perfectly, I connected it back into the system and when the ignition is switched on turned on the car and it ran for a few seconds then stopped, this seemed to be correct & working so then I reinstalled the sender & pump unit after checling that none of the pipes were blocked.
I reassembled everything and then switched on the ignition, I heard the pump run a few times but now it doesn't run when I swithc on the iginition.
I tried to start the car many times also tried towing it to bump start but still the same problem it won't start at all, I fairly convinced that no fuel is being injected into the engine but I don't know why!!
Any ideas - perhaps the injector solenoid is not working or there is some other fault somewhere in the system.
IF anyone can help that qwould be great as I'm out of ideas!!
