i have a stilo o2 reg 1.2 16v active the oil pressure sensor warning light is on but i have checked the oil and it seems fine where is the sensor located so i can clean it or does any one have any ideas how to fix this problem thanx
the oil light is not an indicator of oil level it tells you when the oil pressure is low maybe your oil pump has failed get it checked out ASAP otherwise you will be looking for a fresh engine
