Technical Fiat panda brakes!
Zoikarios140
Hello my friends!
I have a Panda 1.2 2007 model which I bought last week! The car is very very good but with the brakes I am very puzzled ! So I make a search and I ended to put ...
1)Front Brembo max 08.5085.75
2)Ferodo premier FDB1630
3)Rear Brake Shoe Set FSB688
So ...I am listen and your opinion about the set, or which set would you suggest !!!
Can you clarify what you are asking?
Is there something wrong with your brakes or are you just shopping for replacement parts?
The standard brakes on a 1.2 Panda (mine are Bosch) are perfectly adequate - no need to waste money on upgraded ones.
I would agree with lamlash, the standard setup is fine, there is no need to upgrade. If the performance is poor, something needs cleaning or freeing off to bring up to standard.
If you need to replace worn pads and shoes, the Ferodo ones will be great.
if u want better braking on a cheap then best would be Brembo discs and Ferodo pads. Ur option is fine.
Or you can go to the breakers yard and buy a set of used front and rear discs and calipers from 100hp as they are bigger but will be a straight bolt on.
Am I correct in thinking that ur 1.2 Panda has drum brakes at the back? if so then 100hp breaks will upgrade it immensely.
So your opinion is to keep the disc and put only bads ferodo front and shoes rear?
I don't have any restriction with the money. But I am asking you to tell me the best set for my panda!!:):):):):):)
best would be upgrading to 100hp disc breaks all round as ur rears r drum brakes. This way front discs would be larger too. Get brembo front and rear with Ferodo pads and get calipers and adapters for then from ebay. Fiat 500 uses same calipers. U could buy a set that is already painted red too for bit of bling
Hello again! Well...I put new wheels and tires and brakes!
MAK Perfomance Fiorano 5.5x14
ContipremiumContact 5 185/60/14
Brembo MAX
Ferodo premier
I make about 20km and the car is amazing! The brakes are too strong and the feeling is good!
