Finn
- Joined
- Dec 5, 2010
- Messages
- 40
- Points
- 88
Chris, I don't know if it is the same problem! If your lights were going on and off on their own I mean. My problem, which I seem to recall others talking about as well, is that the bulbs just blow out far too often, and always on the same side - in my case on the left side, the battery side, of an LHD car. All bulbs apart from the full beam one have had to be replaced in less than a year, all on the same side, and now the two side lights have gone again. And the bulbs I put in were not cheap ones, so they should last longer than a year. 4 sidelight bulbs, 1 low beam and one fog light in that time is too much of a coincidence! I'm suspecting some kind of spike or power surge goes through that light unit somehow... I need to find the fix!hi there, i have the same problem with my stilo.
the lights are awful. i have tried changing the main d2r bulbs to a higher ones from ebay and they were really good but kept turning on and off on there own so i sent them back. only reason i bought then is that they were £18 and the real ones in the shop was £80. well i learnt my lesson but and i know now not to buy cheap ones off ebay.
the only solution i can find it to try new bulbs from a shop and if that doesnt work then i will get spot lights to fit in the bottom of each grill and make a relay and a switch in the car. this is the only option i have found or the only other option i have found is to change the car as the bip lights on my stilo are really really bad, and i know it sound extreme changing a car just because of the lights are bad but i think after christmas that is my only option
What were the d2r bulbs you mentioned? The main beam bulbs?
