Keep in mind that WD40 and rubber don't go well together. So don't use WD40 on rubber parts you'd like to have a long and happy life.
gr J
Drive belts and a small spray of wd40 to check for quieting - ie belt noise - will cause no issues at all. Wd 40 is safe to use on rubber - its one of those things that does the rounds on the emptynet
From wd40 website -
What surfaces or materials are OK to use WD-40 Multi-Use Product on?
WD-40 Multi-Use Product can be used on just about everything. It is safe to use on metal, rubber, wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40 Multi-Use Product.
