Desmo
Not sure if this is really a technical problem but where on a Mk I Punto 75SX should the engine number be? The handbook says "Stamped on the left of the engine block" but I'm buggered if I can find it anywhere.
I suspect that there may have been a pressed alloy tab which has been detached/broken off but is there a proper stamped in number somwhere?
