Elxpunto90
- Joined
- Mar 24, 2013
- Messages
- 271
- Points
- 53
Hi everyone I can't get my head around this problem I have changed fuel pump ,fuel filter, plugs, ht leads, coil pack ,O2 sensor, coolant sensor, maf sensor idle control valve , cleaned egr valve ,cleaned k&n airfilter , and still having the same problem it passed mot on emissions I tried pulling codes off ecu but item doesn't work it is 3 pin connector I've also tried to do a blink test that doesn't work either
The car starts up from cold no probs it's a bit hesitating and juddering on pulling away I have replaced rear gearbox mount but when slowing down to park up of drive in first before stopping tends to high rev to about 1500 then after about 5 secs eventually goes down to normal but if I'm driving for about 10 mins the engine light comes on water temp is normal fan kicks in quite frequent no smoke coming out of exhaust but I also notice when I'm driving and take foot off throttle car tends to hold back and not stay at a smooth drive I have spent a lot of money on it and time even had head gasket replaced and all sensors replaced apart from the sensor that goes into air filter long round plastic thing with 2 pins has a little resistor in the end of it I think its a air temp sensor ? If I get pic will post it
Any ideas guys really want to get it sorted and I have also got a power drain on car I think it is diode in alternator as I replaced battery and still same problem goes flat after a couple of days of not using it
