- Joined
- Sep 14, 2006
- Messages
- 56
- Points
- 15
Has anyone experienced and sucessfully cured condenation in a rear light cluster. The yellow indicator light shows the most visible condensation, but there is water at the bottom of the unit where the electrical connections to the bottom bulb are corroding.
My options seem to be:
1. Buy a new unit from Fiat (for £74.00)
2. Get one from a scrapyard (which may exhibit the same symptoms)
3. Drill a hole in the unit to let any water collecting out
4. Try to dry out the unit with say silica gel (not easy because of the way the internal parts are sealed). Then try to seal the unit against further water ingress. It is not clear how water is getting in, but I suspect it may be between the part holding the bulbs and the rest of the unit. Perhaps a smear of silicone sealant after screwing the 2 parts together, which would be removeable when future access is required to change a bulb.
I am favouring starting with option 4. The car is a 2006 1.2 Dynamic. Does anyone have any comments?
Andrew
Andrew
