Hi for a few months, you deal with sick of this problem with the carburetor idle, according to who's selskyho reason revolves around who's disconnecting idle at the end of his brass blasting and here's the problem lies so that I work as a decent idle and blasting brass that I must have stripped off, and thus is there only as the valve seals and does not perform its function and consumption is logically higher in the moment when there is blasting go back after idling car is not running already here conk out had twice changed the carburetor unfinished rubber band here as on the nozzle flows into the idle channel in the float chamber several times here but it was cleaning out why it behaves like that here now come to the valve is functional bought new here so anyone had a similar problem and managed to solve it for him so I would grateful for any advice here really ends in this system idle through the channels, I failed to understand
