Technical Can I use an engine wiring loom from a 500 on my 2007 1.2 petrol panda?
Uproaraudio
I've got a 2007 1.2 petrol panda. It's developed a rough idle and hesitant acceleration. I've got fault codes p0204 (injector 4) and p0352 (Ignition coil B).
I've checked the 4th injector with a multimeter, and I'm getting nothing, so I'll be replacing that anyway. I've also swapped the ignition coils around but still getting the same fault code which leads me to believe it's a wiring issue.
Engine wiring looms for the 169s are sitting around £100 on eBay and are impossible to buy from the parts stores. 500s wiring looms can get as low as £30 and there seems to be more of them online.
The question is are they interchangeable since the engine is the same?
Any advice is appreciated. Or if you think I've missed something in my diagnostic please let me know!
Will it just plug in no ECU are are different
Most 500s 1.2 will have two identical size plugs
I suspect yours will have one large and one smaller plug
The wiring to the Cam sensor and Cam sensor even though they Look the same are different
Good probability the original problem will be in this joint
The power for the injectors and coils are all from this same point, it's failed in the past
Thanks, Koalar. That's really helpful.
Do you have any advice on repairing the wiring if I find the culprit?
You need to confirm if this is the problem first
You can back probe the power pin on the injector, with a T pin or similar (brown and red I believe) it the wire that's the same colour on all injectors
Test light or multi meter on volts, probe on the t pin to earth, should be battery voltage with ignition on, wiggle the wires gently see if it goes out
The car not here at the moment, I can do a little video if you want
Reflowing the solder might be a problem, hobby soldering iron does not have enough energy as the mass of copper will soak the heat away, trivel job with a 500w iron
You might just be able to use one of these
Plenty of flux or fresh solder
Awesome. Thank you!
A broken wire to the injector gives this error code, cylinder one was the easiest for me to get to, all further test are on injector 1
The code self clears after 5 starts without errors
On my car it battery voltage on the centre pin of the connector, ECU side
And this can be checked at the injector also
And 2.5V on all the other pins, ECU side
On the injector side of the connector still disconnected
Centre pin to any other pin is around 50 ohms
You can put a long reach handle screwdriver on each injector and your ear to the other, you can hear a distinctive tick as it fired, all 4 should sound the same
With this few tests we have checked
Continuity between the ECU and each injector
The resistance of the windings of each injector
Power is reaching each injector
And if the valve is opening and closing
It will not tell you the spray pattern
This is incredibly helpful. Thank you. Getting my head round electrics is definitely an issue for me but this goes a long way to understand it better.
