So serious shortage of coolant in the system, had to put in a full kettle 1.8 litres of water to fill back up.
Now started to strip down to see if there is anything obvious;
stripped out the battery, tray, ECU and a range of awkward brackets for the harness.
we got the inlet manifold off eventually - not the easiest of jobs and quite fiddly getting the bottom nuts / bolts out, and getting the harness unclipped from the underside, but no sign of heat damage or melting at all, so feel comfortable with that.
got a pretty bad oil leak from cam cover and the belt is desperately in need of replacing as pretty badly cracked, so it's going to get a timing belt kit.
So shopping list so far:
- Rocker cover gasket
- Thermostat
- Cam sensor
- Crank sensor
- Temp sensor (according the dash was up to full temp after idling for 4-5 mins) but clearly wasn't.
- Cambelt kit
- Oil & filter
- Coolant
- Air filter
- Earth strap (even though we have fitted a huge one opposite side of the engine - just rules it out for the sake of a couple of quid)
Trying to locate a timing locking kit is proving a bit of a challenge - can order a £20 one off ebay - but 2 weeks delivery from China, but don't fancy laying out £120 for a professional one for single use.
Whilst have tested the crank sensor - I'm just going to replace both crank & cam sensors for the sake of it just to completely rule them out.
The engine harness is bar a few connectors to starter motor and alternator is almost free, but not going to take out completely as plenty of room to inspect and test the cables now.
Think there is a small leak in the heater matrix , very slight damp on the carpet which as a strange fishy smell (assume this is coolant) - admittedly am thinking K-seal for that rather that stripping the dash to get at it.
looks like a busy weekend and couple of evenings next week...
Managed to borrow a sniffer kit to check for exhaust emissions in coolant to test if the head gasket is compromised - liquid stayed blue so seems reasonable, - also no obvious sign of oil in the water or froth in oil etc.
