i am on my 3rd 500
in a 105bhp S this time and its my first climate control one
i bloody hate it, i think the instruction book is more than useless
and i have some questions about it
if you select auto does this mean the AIR CON is on even if you want the car heating up? cant be ecomonic for the engine if it is on
This is your problem, you've got the usual assumption that AC is for cooling only, which it isn't.
AC light means its 'active' not 'on', IE it'll only be used if it'll help, IE remove moisture for the air etc. So have it on with auto selected is a good thing as its the only way it can be guaranteed to fully regulate the temp in the cabin.
i have tried not to use auto unless its a hot day and want chilling!
No, use it ALL the time!!
but now it is cooler using amnual to set a temp and get the car warmed up is great if your only doing 10 miles, but after that just the blower seems to continue to work and the heat drops off!! any advice
and one final thing
in the old models with normal blower controls what ever you had set when you turned the engine off was what you got when you switched it back on
with the climate control 8 times out of 10 the blower goes back no switched off no matter how long or short the engine is switched off, i find this really annoying
What temp are you using? Set it to about 21.5c (this is what most corporate buildings and offices are set to) and it'll pump out heat when the car is cold (but the engine is warm enough to start pumping out heat) and then start to slow down just to maintain this temp once its got there.
Stick it to 25C+ and this time of year it's likely to never get there and just keep throwing heat out at full pelt
Re it being off when you switch on, this will happen, and is normal, if the car is cold, to prevent it just chucking cold air into the already cold car, as if the engine block is cold you won't be getting any heat. This is actually a rather neat feature. So unless you're steamed up, leave it in auto and the temp about 21.5 and when the engine is warm enough (after about 3-4 min) it'll start pumping heat out. If you've steamed up from the beginning of a journey then hit the windscreen button to get it pumping conditioned air onto the screen from the start.
I think you're not realising just how well programmed and automated the system is, and wanting to think that you can do a better job
