Fair play, although knowing just how inaccurate the Fiat MPG trip computers can be ...
They're certainly inaccurate (real world economy is at least 5mpg less than those figures), but they are at least consistently inaccurate.
I just think for the benefit leaving it activated constantly, even at fuel prices today, it's not worth worrying about. But each to their own.
Agree completely, but if you're 'doing a Maxi' and searching for the next fuel stop with only a vague distant memory of seeing any bars on your fuel gauge, you just might want to hit the off switch
Luckily on the Prius AC is electric, so no power drain from the engine or overall power delivered to the wheels, all run from the hybrid battery and regenerative breaking :devil:
In plug-in hybrid mode, yes - but if you're just cruising on engine power, it's likely even worse, since you also have to account for the losses to generate the electricity to power that compressor. By all accounts, Prius economy is not that great when cruising long distances at 70mph on the motorway (though I'll grant that's not the point of a Prius).
Regenerative braking is one way to use A/C to get something back - on a conventional car, you'll get a bit more engine braking when descending a steep hill if you turn the A/C up to maximum and the extra bit of cooling you get is free
A lot of later EVs (later Nissan Leaf's for example) have heat source pumps though, beneficial in the winter, not sure on their cooking abilities though it if it's in conjunction with a traditional electric AC system.
I guess they suffer the usual problem with heat source pumps - on very cold days (when you most need them), there's not much heat to pump, and they're prone to icing in those conditions.
Air conditioners and dehumidifiers are both really just heat source pumps, the main differences being where you put the evaporator & condenser & how you direct the air.
On a conventional ICE vehicle, there's a huge source of waste heat - the exhaust; finding a way to use even a modest percentage of this could have significant economy benefits and I'm slightly surprised there hasn't been more research done in this area. Even a device which used the exhaust heat to charge the battery could get you 5-10% straight away.
