Technical All-Terrain Tires and Rims for 2011 Panda 4x4 - Can I fit 225/70R15?
malmobalsam
Oslo
Hello everyone,
I'm new to this forum, so I appreciate your patience with my beginner's question.
I'm looking to fit all-terrain tires on my 2011 Panda 4x4 with a 1.2-liter engine. I'm considering getting new rims too since I'm having difficulty finding all-terrain tires that match the original size of the wheels. Would it be possible to fit 225/70R15 tires on it?
Thanks for your help and suggestions!
You can fit whatever you want
Light cars generally don't need supper aggressive wide tyres
And depends what you are trying to achieve
There's no much room in the wheel arches
This is what was originally fitted
Fiat panda 4x4
5.5J x 14 165/70 R14
Climbing
5.5J x 14 185/65 R14
Cross
185 is already quite wide for a 5.5" rim
The more aggressive the tread, the more noisy it will be, driven on road you
The more blocky and softer rubber will overheat and wear quickly if driven hard
upsetting the steering and stability control is also possible, Fiat alter the offset depending on tyre width
ET41 155
ET38 165
ET32 185
ET30 195
I have never tried 225 or know of anyone who has, so I am guessing, I suspect the fronts will hit the inner wheel arch at full lock
195 R15 needs to go on a 6.5" rim really and have clearence issues at full lock in 2wd cars
Fiat panda 4x4
Climbing
Cross
ET41 155
ET38 165
ET32 185
ET30 195
So idealy i would chose a tire that is 165/70 R14 or 185/65 R14.
What about these from pirelli? 175/70 R14. They should do the trick?
Kjøpte du den gule som hadde en del ekspedisjonserfaring?
As far as i know, 185/70R14 or similar is maximum dimention on a unmodified car before they rub.
Some alternatives here:
https://www.bandenleader.nl/auto-band/michelin/latitude-cross/185-65-r15-92t-751647 or https://www.dekkonline.com/rshop/Dekk/Michelin/Latitude-Cross/185-65-R15-92T-XL/R-217784
or road legal rally tyres like these https://www.stianmotorsport.no/prod...rf-zdm3zgm-grushjul-fra-13-til-15″-autogen-2/
Kjøpte denne:
Thanks!!
