General air bag light plus this one keep on flashing
creative335
Hi
can any body help me these lights coming on because my friend put earth wire to live by mistake which blown the fuse for speedo now when its on these lights are blinking on speedo...any body knw how to sort it out
Hi I replaced the fuse for speedo as it wasnt coming on is there any other fuse which need changing as well as these lights are permanently on ...
They're both to do with the airbag, the yellow one usually flashes on start up - it's to do with the passenger airbag and comes on permanately when you switch the airbag off. I'd hazard a guess that the accidental voltage spike has set a hard code in the airbag ECU for a voltage supply fault and just needs clearing with a scanner.
Hi
these both are on even I am driving the car, it use to switch off it self after few seconds but not going away now
To turn off airbag warning lights you need to plug it in and use software to clear the codes, instructions can be found here
Until you've done this its impossible to say what the actual recorded fault is.
@disgusted your fault is a well known problem with the dash earths causing interference with the airbag isolation switch.
You need this video
