Capuyo i have never heard of any stilo that has the wrong pin designations from M10 to D4a you problem does seem very strange.
Heres a schematic of the way it should be wired up from the D4a to a set of switches. please make sure that you have not over looked anything and get back to us.
i have known people not to hook up the 12v feed.
also please note that a constant 12v should be given to A05 to keep the Cruise control active and then you should feed A04, A03 & A02 momentarily to give the speed up, speed down and resume signals to the ECU.
The cruise control dash icon will not come on with out you doing a 'Proxi Alignment' with MES, so you will have no idea if the system is active without taking it for a roadtest at speeds OVER 25mph (40kph). You will not need to wire in 'kill' circuits from the clutch or brake pedal as these circuits are already in place.
hope this helps
EDIT:- after a re-read of your issues it seems to me that you are missing the 12v feed. can you please confirm that you have
1) D4A, the brown connector
2) D4B, the black connector that plugs into D4A
3) that you have a 12v feed to Pin A05 of the D4A
hope this helps
