ducato23hymer
Can anyone help with this?
I have a 2013 2.3 Ducato Chassis Hymer motorhome. I have owned for 5 months and done 12k miles with no issues. It has done 53k miles in total. It was previously owned by 2x individuals and is excellent condition. It went for a full service 3 weeks ago. I have driven a few hundred miles since the service.
During a road trip, a problem presented itself. We had pulled over for a toilet stop. When restarting the engine... The engine started but cut out 2 seconds later. The engine light came on and dash warning "check engine". I persisted, and managed to get engine running again (and stayed running) by just turning the key and trying a few times. I drove to a nearby garage 10 miles away. After parking up and switching off the engine the problem came back.
The AA
The AA came out. Read the fault codes - common rail sensor fault.
He tapped the EGR and the engine ran. BUT, when i tried to rev the engine it then cut out.
We then disconnected and reconnected the common rail sensor. The engine ran, and this time i could rev the engine. We left it running idle for 2 minutes. Switched engine off, then tried to run the engine again. Problem was back again. It just kept cutting out after a couple of seconds tick over.
We changed the common rail sensor - no change. We put back the original.
Fiat dealer
Hymer was transported on back of truck to nearest Fiat dealer. They ran diagnostics and said the crank speed sensor was faulty. They replaced the sensor and cleared the fault codes. No improvement, problem still happens - cuts out after 2 seconds.
The aftermarket immobiliser was checked and eliminated as a source of the issue. This was done by a professional who installed it. We did this because the Fiat dealer said it could be this, so i wanted to eliminate this straightaway.
Does anyone who is an ace mechanic on these engines know what this could be please? Frankly, is seems like a fuel starvation or airflow related issue, but I'm no mechanic.
Thank you.
The AA
Fiat dealer
Thank you.
