Hello everyone I'm new to the forum but unfortunately I come with an issue with my 2008 Fiat Ducato motorhome 2.3 multijet. It cut out on me whilst driving the other day and then would start for a few seconds and then cut out again. Now it will only crank without trying to fire.
I've tried to read codes but I have no communication with the engine ECU, I can communicate with ABS, SRS and BCM all having comms fault with engine ECU.
I've visually checked the engine harness but I have yet to find anything visibly wrong, body earths removed, cleaned and refitted, engine fuses and relays ok, fuse box itself and connectors to it look ok.
I accidentally cut a wire going to the ecu and found when I stripped it back to repair it the copper was corroded. I've been told these can suffer from the copper breaking down inside the plastic coating causing these issues. Has anyone had this?
Can anyone provide me with ecu pinout and or engine wiring diagrams? Or a site where they’re available?
Thanks in advance
Thanks in advance
