that means you paid pertol station prices for the 5l can too
you wiped out time and MPG savings
Time to go hang myself from a tree
Well I'm not getting a diesel 500 that's for sure. I quite fancy a Bravo as a 3rd car, I'd probably go for a diesel or a t-jet
Yea then swap engines around, T-jet in the 500, 1.2 in the Bravo!
Did you do the calculations then? After putting 5 litres in, then using a bit on your way there etc?
It was a couple of hundred metres to the station all downhill so the amount of fuel used would have been negligable. So perhaps it might have used a 100ml or something small but it's not an amount that's worth thinking about.
Like I said it's a negligable amount and not one that's likely to make any difference when you're trying to calculate your rangeI see, was just trying to work it out myself, quite hard to get your head around how many litres used when you use MPG, especially for such a small amount.
I'm happy now just to fill up when the range goes blank. No need to keep on going when I've already got a 500 mile tank under my belt which was my goal all along
Apparently you'd need 42.72 for a 400 mile tank.Yes i meant for me, when I attempt my 400 mile tank!
Just use your brain (unlike I did) and carry 5l of fuel in a tankDo-able then. I nearly did it before with 368 miles/42.5 MPG remember, i just chickened out a bit with the fuel! One day maybe...
Considering there's never been a vacuum when I've opened the filler cap it's safe to say that the tank isn't sealed. I have had cars where the fuel tank does appear to be sealed because you do get a vacuum when you undo the cap.
The pressure is regulated to a very low vacuum by a valve that has the vapour pass into the "charcoal canister" where it sits until that gets filled up.
I think you're right about older cars exhibiting more parp and not being fitted with any emissions control, but it has surprised me how many 90s cars I have had that simply don't work or are blocked, ultimately causing the "too much vacuum to actually draw fuel" issue, which can only be relieved by undoing the fuel cap.At the risk of this thread spiralling off into the argument woods
So what's the issue with having less vapour space? Would not that valve operate as usual (all be it more often if less vapour space) to relieve the vacuum? (As long as there is enough to prevent the cannister being flooded, obviously ) I guess the cannister is nominally maintained at intake manifold (ergo, vacuum ish, lower than fuel tank pressure) pressure?
Is there a site somewhere with an explanation (ie. pretty pictures!) of this system, I guess it's fairly generic these days.
I suspect the previous cars maxi and have had did have a sealed tank, but with less stringent emission requirements weren't required to have the valves or cannister (it was probably good enough to not vent whilst driving or allowed whilst filling up or similar. Although, relieving a vacuum in the tank would not release large amounts of fumes I imagine, especially if a pump nozzle was soon to be inserted*).
*ooer missus
Interesting. I've quite a few 40 and 41 litre fuel ups from various different petrol stations so someone's petrol station is over or undercharging them I guess!So it finally happened. 2 tenths away from the petrol station and the car starts spluttering, then the engine cuts out! Luckily it was slightly downhill so clutch in and i cruised the rest of the way there with my hazards on! How lucky, had to explain to the guy behind though, think he thought i hit black ice!
Anyway, assuming the tank was empty, i brimmed it until i could see fuel sitting in the nozzle end. 39.02 litres?! Not as much as Maxi got in. So what gives? I'm guessing it's the fact that it's a different pump etc, thing is,. I've always used this pump and i've had 40+ litres in before without running out. So either they need to re-calibrate their pumps, or the computer on the car is a little inconsistent!
Here are the stats though, pretty good for an Abarth!
352.6 Miles (2nd best tank, 368 was my best) 39.02 litres to brim and 41.1 MPG
