Hi, I am trying to remove my 2005 2.8 JTD Ducato air filter housing. The filter housing is attached at the bottom to three rubber mounts with nuts accessible inside the housing. Unfortunately the nuts appear to be rusted onto the studs protruding from the rubber mounts. It feels the whole rubber mount is turning when I try to undo the nuts. Can anybody know if I can unbolt the rubber mounts where they are fitted to the chassis are remove the housing with the mounts attached? Are they attached to the chassis with nuts and is there any easy way to gain access to them? Thank you in advance. Kind regards Tony
