Hi all,
i've got an oil leak and having trouble locating its source - i've done an extensive google search, but "oil leak" in combination with "ducato" seems to only result in heaps of Gearbox oil leaks, something i'm luckily not having (at the moment, knock on wood)
My oil leak seems to be originating from somewhere just above the oil filter. Hard to see from below, hard to see from up top.
Its not a huge leak, but dripping after a drive and a lot of parts around there are full of oil. When i wipe it all down and let it run in place, no oil seems to be leaking...
It coming from the "gap" between the oil filter and the sump. (both Oil filter and Sump gasket have been replaced as i initially thought it came from either of those)
Perhaps someone has experience with this kind of oil leak and can tell me what is there that could be the cause of said leak?
See attached pictures (red circling around where it approximately originates)
