looked back into your posts, did you sort out cutting out? is it related to that.
you dont mention swirl flaps.
http://www.ms-motor-service.com/ximages/pg_si_0093_en_web.pdf
have a read of this and check yours are operating correctly/at all. if the bar linkage breaks off the drive flap the others may be stuck open/shut and if the remaining flap attatched to actuator still turns no error message may be displayed.
starting the car the bar will move and turn all flaps approx 1/4 turn.if this is not functioning correctly you may have lost approx1/3 airflow into cylinders if stuck in shut position.
i have also seen you have fes ,you can check with fes there is an actuator test for swirl flaps i think.
also easier to check egr operation with fes, logging maf airflow at idle you will see airflow falling and rising again as it opens/closes i put a graph up in here of normal airflow
https://www.fiatforum.com/stilo/292485-egr-valve-problem.html
maf idle 485-500mg/i egr shut 300-400mg/i with egr open
map boost 970mb-1050mb depends on atmospheric pressure cross check both with just ign on should be pretty similer.
turbo boost solenoid idle=75% if mapped im assuming anywhere down to 20%(check operation manually by observing actuator at idle 75%=actuator pulled fully shut towards radiator lever is pulled to stop=max spool, turn ign off or get someone else to and watch actuator should go outwards away from radiator smoothly approx 10mm)
also with fes check your injector correction values
mine normall settle when warm at less than +/- 1.50 and sometimes less than that +/-0.50 cold start youll probably see +/- 4 or 5 and quickly come down
reving usually drops closer to zero.good indication of any injector issues.
any other things you suspect let me us know ive probably got data here somewhere.
background on map?,cant upload map on here youl have to go to link above its a good site for mapping/mapping issues..
