Trying to decide which dampers to go for on the back of my 100hp as the bushes are probably past their best on mine. I really like idea of going for the oe bilsteins as they designed specifically for the 100hp but i am concered they will be no better at controlling the rear end than the oe setup (has anyone got this setup?).
So next i started looking at koni's, i originally looked at the sports but from this site http://panda100hp.files.wordpress.com/2012/01/koni-13.jpg it seems that the top eye metal insert on these has a bigger ID than the oe units which from an engineering perspective i dont like the idea of.
This then led me onto the koni str which some people say still offer an improvement over standard. Can anyone confirm this along with if they share the same larger top eye metal insert as the sports? Also both the sports and str are non 100hp specific so i assume they will have a longer damper rod, does this cause the spring to become loose when the car is fully jacked up as i dont fancy having to tie wrap my spring on!
