Not many 1.8 owners about? Am having same/similar problem (might as well let you know what i've done :bang:; having said that - use search feature for passenger occupancy sensor, there is a lot of info on it, including a how to).
Cam angle sensor feeds into the left side plug of engine ecu (assuming you are facing your engine bay - it's mounted at the top back end of the engine behind injection rail). It is not such a bad place for it (it doesn't get too hot there) - unplug the connector and have a look at the electrodes (unless you've been flooding e.g. from the screen wash line - it won't be a problem) but to be on the safe side - you can spray some WD40 on the inside of the plug (do the same for cam angle plug - it's blue, you find it left side of the injection rail but on the near side - that is: ecu is behind the rail, cam angle plug is before it on the left - use google: there is lots of info in alfa forums: you guessed it - stilo 1.8 engine came over from alfa - be it with a few modifications and minus twin spark - also punto HGT and barchetta use the same engine). If WD sorts it for a couple of days (spray some more once the error is back - if it doesn't clear after 3 restarts its unlikely to be a connection issue).
Cam sensor itself seems to be very sensitive (it would be - considering it is sitting on the hottest part of the engine fiat could find) and seems to fail after 4-6 years (as any Bosch part would?) however, it can also get "confused" - exhaust cam pulley tends to rust - rust flakes off and sticks to the sensor (as it is HALL effect sensor - this eventually becomes a problem). There is also a possibility that you have a problem with crank shaft sensor (the two work in tandem - if reading from one is different - you have a problem and YES your ECU will trust Crank sensor over Cam sensor). Crank sensor is cheap though (about 30 squid) and is easy to replace (lower back of the engine - get at it on the ramp).
If that fails than it is likely to be one of 4 problems:
1) Engine ECU wiring loom (this is very rare – but fairly easy to test: wiggle wires about with car started but clear error codes first: when you hear BEEB BEEB you got it or you could just test the wires: anything will do even a battery and LED + pinout – use the force.. erm google :yum
2) Cam angle sensor (likely) and/or wiring (it does chafe if installed badly.. it would do - sitting between engine and water pump... - but this is rare as fiat techs use ALOT of silicon
- hence gluing cam wires behind the pump: good luck taking it out without breaking water pump seal.. took me 30 min :yuck
3) Crank sensor and/or wiring (quite common - though mostly on JTD.. but there are many JTD about and just a few 1.8s)
4) Engine ECU (really rare and presents itself with other issues too).
Hm – are you sure your cam angle sensor was replaced? To do that you need to take the Timing belt off (and replace it if it has done > than 3000 miles and if you do that you would also need new tensioners...) + take exhaust pulley off (so timing needs to be redone)... it takes me 6 hours to do all that (with fiat tools) if you did yours at an independent ... and they charged you less than 4 hours labour...GOOD luck to you
Hope this helps.. personally i was stupid and replaced me sensor without a proper cam pulley holder (hence warping the inside of the pulley, which then grinded on my new sensor causing it to fail
stupid me) so i cleaned the old one and put that back on – it worked for 3 months– but now it is starting to fail
(can do a how-to with pics in exchange for a new 1..
PS: if you cam goes completely your car will not start ..
PPS: your friendly fiat place can test your cam sensor for you... :yum:
