- Jan 18, 2017
- 87
- 27
I am getting this message occasionally when I turn off the ignition on my Stilo 1.2 along with a couple of beeps and a host of other error messages which don't make sense, ie engine failure, alternator failure, abs failure etc etc when everything appears fine and drives fine when I start the car up and drive. With the ignition off and key out the error display remains lit and won't go off.
Leading up to this I hadn't driven the car and left it parked up for a couple of weeks, I did notice a beeping noise near the car but didn't realise it was coming from my car until I tried to start it and flat battery!! So I charged up the battery and everything seemed fine for a while until I started getting this error message again.
Now I'm wondering if anyone has had this error before and what was the cause? could it be an error the system throws up when the battery is going wonky and not delivering the correct power? Or have I actually got a loose connection?
Thanks in anticipation, any ideas or thoughts welcome.
