I got new Qh clutch kit fitted to my Stilo 1.2 approx 18 months ago and has covered around 12,000 miles since. Around 6 months ago, the release bearing started squealing and squeaking when the clutch was pressed but didn't get any worse.
Two weeks ago, my car got bogged down in mud and I rode the clutch pretty hard trying to get out. In the end, I gave up and had to be towed out. In the last few days, I've noticed that gearshifts have become very notchy and sometimes the stick really has to be pushed home quite hard. The clutch now bites with the pedal just lifted very slightly off the floor. A check on the slave cylinder and the fluid show all is fine. The piston ejects as soon as the pedal is pressed and moves progressively till the pedal hits the floor. The gear shift is fine with the engine stopped, and there's plenty of oil in the box. It looks like the clutch is not fully disengaging with the pedal fully depressed.
I'm wondering if trying to get the car out of the mud has damaged the pressure plate or release bearing in some way. Anyone any thoughts ??
