I'm new to the Dark Side... so please bear with me..
The EML is permanently on and the car idles perfectly. It drives "not bad". Of course it has just 115 old donkeys in there..
but it still feels like it's just missing some urge.
In the lower gears things are fine .. it'll accelerate over 3000rpm.. but at higher speed it struggles a bit. I'm revving it occasionally, under a light load, to 3500 rpm when I can to help flush out any soot.. and it seems to be improving..(?) but the EML stays on.
Exhaust is clean - no excess smoke or soot. Almost petrol-like actually.
Do EGRs "self-clean" (for instance if I fed the beast some Ethyl-Hexyl Nitrate
) or is the easiest (!?) if not the quickest solution just to clean/replace the EGR valve?
If I clean/replace the EGR (and it's the cause of the EML), will the EML go out all by itself or do I need to have an error code cleared once it's in the ECU memory?
Ta,
Ralf S.
