The 1.2 & 1.4 16V engines don't have a normal rocker cover, they have a cylinder head extension. This means you have to lock the cams, remove the timing belt, drain the coolant, remove all electrical/ignition components, then unbolt the extension before you can access the gasket. You also have to be careful not to lose the hydraulic lifters!
