Technical Stilo abarth speedometer lcd fault?
Nufc4life1982
Hi I recently changed my standard speedometer for an abarth speedometer and everything was working fine until I noticed a few days later that I couldn't see what was being displayed on the Lcd screen even tho u can see the backlight, but I can just see it if I moved my head around, is there a quick fix or do I need the lcd replaced and dose anyone know who is the cheapest to fix this ?
Thanks guys I've got this back up and running now, so u say this won't happen anymore as it only happens once after changing them, hope it dosent happen again but again thanks for ur help guys, also guys am due my mot nxt month will the new cluster be ok for test?
Dose anyone know if the new cluster will be ok for my mot test or will I need to change them over ?
Yehh everything works just get headlight sensitivity in the lcd when I start up sometimes only happened since I pulled battery for the led fault but mileage doesn't flash as I proxy aligned it thanks for the help
