benyboy95 New member Joined Feb 24, 2014 Messages 49 Points 11 Jun 4, 2014 #1 Hello all does anyone know where to get the tool to take off the rocker cover or if i can use any thing else ?
richydraper Prominent member Written 10+ guides Joined Nov 30, 2006 Messages 2,780 Points 692 Location Coventry Jun 4, 2014 #2 you mean for the bolt heads?
M mhowse Patron member Joined Apr 16, 2008 Messages 642 Points 137 Location North Scotland Jun 4, 2014 #3 Read what richy says, deleted my wee bad hair day and torx means ribe in my world .. but def ribe bit set as man below says Last edited: Jun 4, 2014
richydraper Prominent member Written 10+ guides Joined Nov 30, 2006 Messages 2,780 Points 692 Location Coventry Jun 4, 2014 #4 mhowse... you're wrong! (in the nicest possible way) the correct tool is http://www.machinemart.co.uk/shop/p...-ribe-power-bit-set-22-piece?da=1&TC=SRC-ribe they're called 'Ribe' and have a square profile compared to torx. If you use torx you run the risk of rounding out the profile of the bolt head... i, for one, wouldn't fancy drilling them out.
M mhowse Patron member Joined Apr 16, 2008 Messages 642 Points 137 Location North Scotland Jun 4, 2014 #5 Yep you are totally correct ..off to bash me head against the wall:bang: was the ribe set admit got em mixed up have to scrub that last post out but lost me eraser too, keep to old fashion nuts n bolts me thinks
OP OP benyboy95 New member Joined Feb 24, 2014 Messages 49 Points 11 Jun 4, 2014 #6 Yes the bolt heads cheers i will be ordering myself a set of these cheers
J jim cooper Patron member Joined Jan 1, 2007 Messages 728 Points 262 Location Bangor, County Down Jun 6, 2014 #7 Ribe is a Fiat speciality. easy to get a set on Ebay for not much money. http://www.ebay.co.uk/itm/US-Pro-To...t=UK_Hand_Tools_Equipment&hash=item3a8304ad6d This post contains affiliate links which may earn a commission at no additional cost to you.
