bambam5521
- Apr 15, 2014
- 4
- 1
Hi guys, first things first, hi everyone ive joined this forum in the hope of finally resolving an issue with my stilo and after lots of research and money spent I am at the end of my teather hoping collective knowledge can help!
long story short purchased a 54 plate stilo 1.6 active sport 71k on clocks fsh a little while ago all seemed good however after a short while it started randomly cutting out locking up ive seen its very well documented on here.getting a mixture of immob alternator coolant temp errors I proceeded to investigate, checked all fuses and earths battery seemed ok 12.2v sat 14.1 running all earths under 0.5v loss came to check d4 upon this forums recommendations cleaned with contact cleaner still no avail. However I did notice under fuse tray there is another d4 style connector lying loose wrapped in cling film is this correct??
moved on to fault codes and got p0105 p0115 p1121 p1122 p0480 p0230 p0638 u1600 u1702and u 1700
most of these are circuit fails so my assumption was ecu so I purchased a tested recon with warranty installed every thing popped up no drama and was fine for 5 days today engine light came on with codes u1702 u1600 u1700 u1706 reset codes and was fine for 3 hours then popped up again. Im not sure and close to giving up so im hoping you guys can shed some light for me
thanks in advance
liam
thanks in advance
liam
