Just putting one of my thoughts out there.
I was wondering if it would be possible to fit the Abarth discs, pads and calipers to my 1.2? I know they have an overall larger diameter and thickness but have the same center bore so would at least fit on with my caliper/ carrier out the way. Would the caliper carrier bolt up fine on my 1.2's hub carrier? If so then the disc should fit and the caliper over the top.
But if not then I'll need the Abarth's hub carrier...will that fit
Considering there's Brembo big brake kits out there for over a grand of which I doubt would be much bigger than the standard Abarth setup then I see this as a viable upgrade for the 1.2, and it will fill the gap in the Blades much better as well
Thanks in advance
-Mark
Thanks in advance
-Mark
