Im on my phone so struggling searching at mo,
Ther was a guy with name dax I think, was trying to Turbo an abarth and I don't remember him ever getting there.
I think Nikos or similar name managed to turbo a 1.6 or 1.8 but went on to bigger things.
I've no idea what turbo is t-jet, but I'm guessing it's just a standard wastegated turbo. They look similar with actuator but they're not really the same, the actuator on the wastegated turbo is connected to a flap valve usually that vents excess exhaust pressure to maintain a set boost pressure.
Say actuator is 12 psi, the exhaust gas will drive turbine up to a speed wher it will deliver boost depending on exhaust gas/shaft speed, as pressure in boost side reaches 12 psi the boost pressure passing down the pipe to the actuator and overpowers the actuator spring which causes the rod to open the flap inside the turbo and vent exhaust gases to bypass the turbine and maintain 12psi, pressure drops below 12 and flap closes shaft speed increases boost increases. And so on, as development would be required I would think an adjustable actuator ideal.
Your already thinking about compression ratio, also think modification to ignition system turbo may require stronger spark.also you will need modification to ignition timing?you may need increased engine cooling and most likely increased oil cooling, turbo camshafts usually run different timing,
What sort of torque would a 1.2turbo generate and what torque will Rods take?
What nm will gearbox take, clutch take.
Exhaust will probably need increasing in size a fair bit as well.
Mapping and control? It will need to burn clean enough to pass your vehicles emisions parameters for mot time?
What's the pressure range on your cars map sensor?
Don't want to put you off but there's a reason everyones not doing it.
Have a look for some UNO conversions to turbo or even x1/9 turbo conversions to see what involved.
Here's a link to engine / gearbox nm levels right at bottom is gearbox input torque, it looks like you may be going from 100nm to 200+ nm, a fair jump.
http://www.tezana.pl/files/do pobrania/FPTOVERVIEW.pdf
