Had this car for a little over a month now and even though it's a relatively smooth runner and hasn't really given me any major problems, there have been a few bumps...
Fiat Stilo 1.6 16v AC, 5 Door, Petrol, 64000miles, 53plate, £1400 a month ago...
1) When the engine starts and it is still cold, I get a bit of a soft engine rattle at lower revs. Heard from behind the steering wheel when doors/ windows closed but a bit more obvious from front of car when they're open. It's not really a clunky tractor rattle, more of a higher pitched soft rattling when in the lower rpm range in any gear, after around 3000 in a gear it goes away, until I shift up to the next where it begins again. And this only happens whilst engine temperature is low, after about 10-15 mins of driving it warms up and the sound goes away. Can be drowned out with music, but sounds rather embarrassing from the outside say when i'm reversing out of a friend's driveway. And it's a petrol so usually don't expect much rattling.
2) Clutch makes a clicky kind of squeaking sound when I press down on it. Sounds like a sqeak if I press my foot down quickly but when I slowly lower and lift the clutch it's actually a lot of tiny clicks, like teeth of a comb.
3) Steering makes a distinct squeaking/ whining whenever it feels like it tbh. Sometimes it's silent, sometimes it sounds like a cat stuck under the car and it happens at any random time. Could be dependent on weather. Happens both in city mode and not.
4) Aircon problem- just paid to get the full AC service at the local dealership £50 which included regassing, leak checks, pressure checks, anti- bacterial cleanse, filter checks and anything else normally included. However, as they were doing it they told me that my AC was not working, as in air was coming out of the vents, you could press the AC button and the light comes on but the whole system was not engaging. They said a clutch? was not engaging. After doing checks for leaks, cracked pipes, all the usual problematic stuff, they still said they could not find the problem and they'd have to put it on the diagnostic machine. They mentioned it could either be a cheap switch or a pricy compressor. However they still charged me for the freaking service, and I did notice the air coming out of the vents to be slightly colder but still not 'AC'ed.
Just thought I'd pass these problems by the Forum first as I've been helped out enough in the past just by searching or posting here. The Fiat dealership has told me to let them put it on the diagnostics system for these problems but it seems to me they'd find any excuse to rob motorists of £76 plus VAT per hour!!! to just check what the problem is and let me know (without actually fixing it)...
So before I go ahead and blindly let them take my money I was wondering if I could get any advice from anyone on here or if I should take it to a private garage first, as I know quite a few locally.
Thanks in Advance.
(Sorry if there's already been posts about any of the individual sections in this post, I would appreciate any links with solutions if there are any)
Happy to post pics if required (but more of an audio problem...)
Thanks in Advance.
