neonglow
Member
- Jul 12, 2010
- 347
- 53
Could be the chips. What are you looking at are solid state relays. I haven't researched enough but you should be able to order them somehwere if that turns out to be the problem. Here are some links I came across: http://www.datasheetcatalog.org/datasheet/stmicroelectronics/7392.pdfWhen I removed the board from its plastic case I noticed one corner of the board was warm/hot so I just took a really close look at it and this is what I found.
Looks like 2 of the chips have over heated?
Any electronic wizz kids want to give me their verdict?
The heat seems to have melted some see though brown stuff around the pins of the chips?
Edit.
Just cleaned the brown stuf off incase it was causing a short.
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00002417.pdf
I really thought the ECU was more protected, never thought it would be a simple exposed PCB bolted onto the engine where temperatures easily reach 100 degrees centigrade
