Firstly appoligise, I know this has been covered but I'm on my blackberry at the moment and searching the forum on it is a pig.
Stilo is currently in the air at the garage as we've got the rear axle off doing the bushes. I've noticed a coolant leak, its on the shroud under the rad and around the N/S wheel cover. Checked the obvious quick release couplings and that's dry, even checked the LPG regulator as that uses a coolant feed and is located there and that is also fine. So I suspect it might be the rad itself. Need to remove some of the plastic surounding it before I can see, if I remove the shroud at the bottom of the rad its not just going to fall out is it?
Its caused a bit of a pain as were off on a 1000mile journey between tonight and saturday in the ole girl.
Many thanks. Jonathan
(Ps, if a mod is able to murge this thread with another or the like then that'd also be a great help ta).
