suzukib
Hi all im new to the forum and desperately need some help from you knowledgeable people!
Ok so i have a 2003 fiat stilo dynamic in the best colour......YELLOW. I love(d) the car up until last week. got home, parked car up with usual routine after the rat run, went to leave for work the next morning and it was cold -3 to be precise, so i fired her up and let her warm whilst i attended to the ice on the windows etc then drove up the road to commence the new days rat run....this is where the fun starts:
Got to the top of my road and it just died, i thought well it is cold and re started her and carried on......next time i stopped it died again....re started and pressed on… about 5 miles into the journey i get the scary beeps and **engine fault** i think oh great and nursed her to work and contemplated what was happening!
The symptoms are more on the tick over side and the fact it wont hold a tick over, it floats between 700-1500 rpm then dies. so after a 12 hour shift i try to get home.....same problems every time i stop it dies, but now when driving the accelerator just stops working by this i mean it acts as if it stalled so i put the clutch in and the engine is still ticking over but the pedal wont rev the engine until you turn it off and re start....5 mins later it happens again......the engine fault light still remains lit on the dash.
So after hours of forum searching and google searching i decided start with the basics and replace plugs and battery....to no avail! Next stop diagnostic test and it came back with lambda 1 erratic. coil 1-2-4 1800 coil 3 1500 so coil 3 was lazy. so i have put 4x champion coils in (as recommended by this site) to go with the new batt and new plugs and new exhaust from cat back. The problem is still there.
The theory I have come up with is cylinder 3 was not burning fuel correctly due to lazy coil, so the lambda is picking up wrong gasses and adjusting everything thus causing the rough running…..but I think im wrong!
I have ordered a pre-cat lambda and that should, with any luck be here Friday. I haven’t yet played with the D4 connector or cleaned the throttle body connectors but i have cleaned the throttle body butterfly valve (as recommended by this site) and still it wont hold a tick over. if i can recall from memory the car was throwing out an injector fault code that i think was P0101 and a P0103 or something like that unfortunately i dont have the diag sheet to hand as im at work.
Sorry for the long post but i thought i would give as much history as possible to aid your expertise and i would greatly appreciate any advice given. The car had a full service 3 months ago and the mileage is 64k with full service history etc and it has never wanted for a part in its life. i have spent over £500 this month trying to sort her out and funds are now extreeeeeemly low, my girls cant have a great xmas now because of this
kind regards,
Mike.
At his wits end. May torch her and claim on the insurance!!!!!! :slayer:
P.S im competent with engines, but i mainly build bikes and bike engines. Hence the name lol
kind regards,
Mike.
